the datasheet of the LMZ36002 only contains the Thermal Pad Mechanical Data, but there is no information about the Land Pattern Data. Where can I find the Board Layout and Stencil Design for RVQ (S-PB3QFN-N43) ?
Andreas
Andreas
Hi Andreas,
I will point this out to the apps engineer who wrote the datasheet. There must be some linking issue that caused the stencil and layout drawings to not be populated in the datasheet.
In the mean-time, I am waiting for the internal data server to finish it's maintenance. When it is done I should be able to find the full file that includes package outline, example board layout and example stencil design that can be normally seen on the newer datasheets.
Jimmy
Hi Andreas,
I was able to get in contact with the apps engineer and have him provide these files in a pdf document.
Attached are the mechanical data for the RVQ package. Let me know if you need anything else.
LMZ36002 Mechanicals RVQ43.pdf
Jimmy
