I have designed an circuit on webench and It work well. There is no problem. I get 55V , 1.2A output.
I need your support to understand the filter area. Because Webench does not give any information for them.
• Which value should I use for CX?
• Which value should I use for Rx1 and Rx2? What is the mission of this part?
• Which value should I use for L1?
• Which value should I use for Cy1 and Cy2? Should I connect the EARTH INPUT center of them? Does Chassis GND mean Earth?
• Should I use varistor in input area? If yes, which value is ok for my circuit?
I am not a professional designer so I need your support. According to your reply, I finish my GERBER to produce my PCBs.
Best Regards
