Part Number: TPS56528
Other Parts Discussed in Thread: TPS56C215Hello,
The OVP function in the device listed below is latch-off? If so, how to get back to the normal operation after OVP?
TPS56527
TPS56528
TPS56C215
Kazuto
Hi, OVP should be non-latch protection for these parts, after OV released, converter will go back to normal.
Yuchang
Hi Kazuto, when OVP happen, both HS and LS should be off, I checked some file found no delay for the OVP happen, and generally OVP will be released after IC detect Vout is normal, From the datasheet, discharge will not be enable for 56527/8, but seems it is available for 56c215, I will double check for this.
Yuchang
