Hi Team,
I have several questions about bq25700A, please kindly help to answer.
- What is Fault_OTG_OCP in 0x20H? There is no info in below descriptions diagrams
The faults are latched until a read from host. -
SYSOVP_STAT
Hi Team,
The faults are latched until a read from host. |
SYSOVP_STAT |
Hey Hollis,
1. In OTG mode, if the OTGCurrent() register setting threshold is surpassed and causes the OTG voltage to drop below the OTG undervoltage threshold, this fault will trip.
2. Your understanding is correct. If the fault occurs, but then is removed, it is latched until the host reads it. However, if the fault is still present, reading from the host will not clear the fault flag.
3. To clear the SYSOVP converter latchoff, you must write this bit to 0. This fault both latches the register and the converter.
Joel H
