Team,
can you advise what is the spec. for Maximum Duty Cycle DMAX and Minimum ON Time tON MIN for the TPSM53604 module?
Couldn't find this in the datasheet.
Thanks for your help!
Hi Bart,
The typical duty cycle is not usually characterized.
The maximum duty cycle is generally a calculated equation where:
However if you want to have a calculated value of your application's typical duty cycle you can use the following equation:
Jimmy
