I have a problem with lion charger BQ24070. About 10% of our products arrive to fhe service with the BQ24070 broken. In particular the IC has the following problem: even if there is the correct input voltage on the IN pin it does not output any voltage on the OUT pin. My suspect is that Q1 is broken. Of course battery is not recharged but I suppose this is a consequence of the previous problem.Attached you find the schematic of our circuit. I am not able to understand what the problem is. Is it possible an ESD problem? I wait your response as soon as possible.
Thanks in advance.
Best Regards
David Paoli
Aep Srl
Italy
