Hi Sir,
I have 2 questions about the application of BQ25700A, I appreciate your suggestions.
1. I see there is a Peak Power Mode in the datasheet. Is there any limit for the Peak Power Mode? such as time is limited or something. May I always turn on peak current mode to achieve a high power charger? any concern about this?
2. About the voltage sense. If there is an already known voltage offset of the sense resistor because of the bad kelvin sense, can I set the register or change somewhere to compensate the offset?
Looking forward to your reply.
Thanks.
Penn
