Other Parts Discussed in Thread: TL431LI-Q1, , TL431
Hi Team,
I am a bit confused by the minimum cathode current spec in the datasheet. Under recommended operation conditions, the minimum is specified at 1mA. However, the Imin spec in table 6.6 shows 0.7mA max and 0.4mA nominal, with no minimum spec. Can you please help me understand why these numbers are different and why Imin is spec'd with a max value and not a min value?
Thank you,
Jared
