Can LMR16006 SHDN pin be controlled with microcontrollers 3.3V output?
HI:
can you describe more detail for your question?
for 3.3V output , is it LMR16006 output or from other rails? you used microcontroller's IO or its VCC control the EN of LMR16006?
MCU is powered from different source. I want to use GPIO of MSP432 to control ON/OFF of LMR16006(48Vin, 5Vout).
hello Mindaugas,
You just need to ensure proper logic levels as defined in datasheet, with respect to power converter ground.
