The VDD and RESET pins have the same pull-up power supply.
The TPS3840 has VPOR specifications.
When VDD is lower than VPOR, the voltage shown in Figure 5 can be seen on the RESET pin.
Could you tell me how to suppress this voltage?
Since it is better to keep the reset signal level unchanged, I would like to avoid placing a resistor between RESET and GND to divide the voltage.
Or is there a device that can fix the RESET pin to low level when VDD is lower than VPOR?
Yuto Sakai
