Hi team,
My customer now uses TPS92692-Q1 in their headlight product, LED current is 1A, and they want to use hiccup mode, so they connect FLT pin to SS pin.
They find that when the high beam light switches to low beam light(using MOSFET to bypass several LEDs), the LED current will ramp up to 2A for 600 us and trigger LED string over current protection, enter into hiccup mode, causing the low beam light blink.
So I want to ask is there any solution we can solve this issue? Like adding LED string overcurrent response time to blank this unwanted 600us high current? Or add a 100ohm+1uF RC low pass differential filter between CSP and CSN, is this solution valid?
Thank you.
Gary
