BQ25150EVM: bqstudio "supported targets" list cant find BQ25150EVM listed.
Part Number: BQ25150EVM
Other Parts Discussed in Thread: BQSTUDIO, , BQ25155
Hi TI:
First time user of BQ25150EVM, fired up bqstudio, can't find it in its "supported  targets" list.
What should I do? Thanks.
    Did you download the BQSTUDIO test version?
  • No I downloaded the stable version.
  • It's very simple and easy to see the problem yourself.
    Just install bqstudio. In the "supported targets" list do you see bq25155?
    I bet you don't.
  • The file is available in the test version.
  • Hi I downloaded and intalled the test version, only that it can't launch, giving this message:
    Log file is below:
    !SESSION 2020-03-20 20:40:04.363 -----------------------------------------------
    eclipse.buildId=unknown
    java.version=1.8.0_74
    java.vendor=Oracle Corporation
    BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
    Framework arguments:  -clearPersistedState -persistState false
    Command-line arguments:  -os win32 -ws win32 -arch x86 -clearPersistedState -persistState false
    !ENTRY com.ti.evswsdk 4 0 2020-03-20 20:40:06.125
    !MESSAGE FrameworkEvent ERROR
    !STACK 0
    org.osgi.framework.BundleException: Could not resolve module: com.ti.evswsdk [190]
      Unresolved requirement: Import-Package: com.ti.evswsdk.dashboard
        -> Export-Package: com.ti.evswsdk.dashboard; bundle-symbolic-name="com.ti.evswsdk.dashboard"; bundle-version="1.2.0.202002211139"; version="0.0.0"
           com.ti.evswsdk.dashboard [219]
             Unresolved requirement: Import-Package: com.ti.evswsdk.gpcpackager.views
    	at org.eclipse.osgi.container.Module.start(Module.java:434)
    	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)
    	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1561)
    	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)
    	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)
    	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
    	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
    	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
    !ENTRY com.ti.evswsdk.authentication 4 0 2020-03-20 20:40:06.134
    !STACK 0
    org.osgi.framework.BundleException: Could not resolve module: com.ti.evswsdk.authentication [193]
    !ENTRY com.ti.evswsdk.calbq769x2 4 0 2020-03-20 20:40:06.140
    !STACK 0
    org.osgi.framework.BundleException: Could not resolve module: com.ti.evswsdk.calbq769x2 [200]
      Unresolved requirement: Import-Package: com.ti.evswsdk.programming769x2
        -> Export-Package: com.ti.evswsdk.programming769x2; bundle-symbolic-name="com.ti.evswsdk.programming769x2"; bundle-version="1.0.0.202002211139"; version="0.0.0"; uses:="org.osgi.framework,  org.eclipse.swt.graphics,  org.eclipse.jface.resource,  org.eclipse.swt.widgets,  org.eclipse.jface.dialogs,  org.eclipse.ui.plugin"
           com.ti.evswsdk.programming769x2 [253]
    !ENTRY com.ti.evswsdk.cmdsequence 4 0 2020-03-20 20:40:06.145
    !STACK 0
    org.osgi.framework.BundleException: Could not resolve module: com.ti.evswsdk.cmdsequence [216]
    !ENTRY com.ti.evswsdk.dashboard 4 0 2020-03-20 20:40:06.151
    !STACK 0
    org.osgi.framework.BundleException: Could not resolve module: com.ti.evswsdk.dashboard [219]
    !ENTRY com.ti.evswsdk.dataflashview 4 0 2020-03-20 20:40:06.155
    !STACK 0
    org.osgi.framework.BundleException: Could not resolve module: com.ti.evswsdk.dataflashview [220]
      Unresolved requirement: Import-Package: com.ti.evswsdk.fsexport
        -> Export-Package: com.ti.evswsdk.fsexport; bundle-symbolic-name="com.ti.evswsdk.fsexport"; bundle-version="1.0.0.202002211139"; version="0.0.0"
           com.ti.evswsdk.fsexport [228]
    !ENTRY com.ti.evswsdk.fieldprogrammer 4 0 2020-03-20 20:40:06.159
    !STACK 0
    org.osgi.framework.BundleException: Could not resolve module: com.ti.evswsdk.fieldprogrammer [226]
    !ENTRY com.ti.evswsdk.firmware 4 0 2020-03-20 20:40:06.163
    !STACK 0
    org.osgi.framework.BundleException: Could not resolve module: com.ti.evswsdk.firmware [227]
    !ENTRY com.ti.evswsdk.fsexport 4 0 2020-03-20 20:40:06.167
    !STACK 0
    org.osgi.framework.BundleException: Could not resolve module: com.ti.evswsdk.fsexport [228]
    !ENTRY com.ti.evswsdk.gdk 4 0 2020-03-20 20:40:06.171
    !STACK 0
    org.osgi.framework.BundleException: Could not resolve module: com.ti.evswsdk.gdk [230]
      Unresolved requirement: Import-Package: com.ti.evswsdk.dataflashview
        -> Export-Package: com.ti.evswsdk.dataflashview; bundle-symbolic-name="com.ti.evswsdk.dataflashview"; bundle-version="1.3.0.202002211139"; version="0.0.0"
    !ENTRY com.ti.evswsdk.goldenizing 4 0 2020-03-20 20:40:06.175
    !STACK 0
    org.osgi.framework.BundleException: Could not resolve module: com.ti.evswsdk.goldenizing [233]
    !ENTRY com.ti.evswsdk.programming769x2 4 0 2020-03-20 20:40:06.180
    !STACK 0
    org.osgi.framework.BundleException: Could not resolve module: com.ti.evswsdk.programming769x2 [253]
    !ENTRY com.ti.evswsdk.authentication 2 0 2020-03-20 20:40:06.631
    !MESSAGE Could not resolve module: com.ti.evswsdk.authentication [193]
    !ENTRY com.ti.evswsdk.calbq769x2 2 0 2020-03-20 20:40:06.636
    !MESSAGE Could not resolve module: com.ti.evswsdk.calbq769x2 [200]
    !ENTRY com.ti.evswsdk.programming769x2 2 0 2020-03-20 20:40:06.641
    !MESSAGE Could not resolve module: com.ti.evswsdk.programming769x2 [253]
    !ENTRY com.ti.evswsdk.goldenizing 2 0 2020-03-20 20:40:06.645
    !MESSAGE Could not resolve module: com.ti.evswsdk.goldenizing [233]
    !ENTRY com.ti.evswsdk.dashboard 2 0 2020-03-20 20:40:06.649
    !MESSAGE Could not resolve module: com.ti.evswsdk.dashboard [219]
    !ENTRY com.ti.evswsdk 2 0 2020-03-20 20:40:06.653
    !MESSAGE Could not resolve module: com.ti.evswsdk [190]
    !ENTRY com.ti.evswsdk.firmware 2 0 2020-03-20 20:40:06.657
    !MESSAGE Could not resolve module: com.ti.evswsdk.firmware [227]
    !ENTRY com.ti.evswsdk.fsexport 2 0 2020-03-20 20:40:06.661
    !MESSAGE Could not resolve module: com.ti.evswsdk.fsexport [228]
    !ENTRY com.ti.evswsdk.dataflashview 2 0 2020-03-20 20:40:06.665
    !MESSAGE Could not resolve module: com.ti.evswsdk.dataflashview [220]
    !ENTRY com.ti.evswsdk.fieldprogrammer 2 0 2020-03-20 20:40:06.669
    !MESSAGE Could not resolve module: com.ti.evswsdk.fieldprogrammer [226]
    !ENTRY com.ti.evswsdk.cmdsequence 2 0 2020-03-20 20:40:06.675
    !MESSAGE Could not resolve module: com.ti.evswsdk.cmdsequence [216]
    !ENTRY com.ti.evswsdk.gdk 2 0 2020-03-20 20:40:06.679
    !MESSAGE Could not resolve module: com.ti.evswsdk.gdk [230]
    !ENTRY org.eclipse.osgi 4 0 2020-03-20 20:40:06.685
    !MESSAGE Application error
    !STACK 1
    java.lang.RuntimeException: Application "com.ti.evswsdk.evswsdk" could not be found in the registry. The applications available are: org.eclipse.e4.ui.workbench.swt.E4Application, org.eclipse.e4.ui.workbench.swt.GenTopic, org.eclipse.equinox.app.error, org.eclipse.help.base.infocenterApplication, org.eclipse.help.base.helpApplication, org.eclipse.help.base.indexTool.
    	at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:248)
    	at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
    	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
    	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
    	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
    	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
    	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    	at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
    	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
    	at java.lang.reflect.Method.invoke(Unknown Source)
    	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
    	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
    	at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
    !STACK 0
    !STACK 0
    !STACK 0
    !STACK 0
    !STACK 0
    !STACK 0
    !STACK 0
    !STACK 0
    !STACK 0
    !STACK 0
    !STACK 0
    !STACK 0
    !STACK 1
    I'll suggest you uninstall the version you have on your computer and delete all files in the folder below and reinstall the test version.
    C:\ti\BatteryManagementStudio
