Other Parts Discussed in Thread: TPS7B4253-Q1, TPS7B7701-Q1
Hi Team,
On customer side, we want to use TPS7B6701-Q1 to replace LT3605. For TPS7B6701-Q1, the voltage tolerance on Output pin is -0.3V~22V.
But for LT3605, the voltage tolerance on output voltage is -40V~40V.
This parameter is very important for customer, the output voltage may connect to battery for some failure mode in customer's application.
Could you check it and recommend a suitable device for me? Thanks.
TPS7B67XX-Q1 datasheet screenshot
lt3605 datasheet screenshot
BR
Songzhen Guo
