Hi team,
Please review the schematics for TPS546D24A which is attached below.
Our configurations are,
VIN = 12V
VOUT = 3.3V
IOUT = 25A
PMBUS ADDRESS = 0X1F
Hi team,
VIN = 12V
VOUT = 3.3V
IOUT = 25A
Hi Chandrasekhar,
Did you use WEBENCH to create the design?
Gerold
Chandrashekhar, in addition to Gerold's question, please upload a higher resolution image of the schematic (or pdf). I cannot make out any component values in the image you posted.
Kris
Hi Gerold,
Yes, we used WEBENCH for design and also we referred Reference designs and datasheet.
Hi Kris,
Sorry for the poor image. PFA for the PDF of the same schematic.TPS546D24A.pdf
Thanks, the pdf is a lot better. I will review and get back to you with feedback by tomorrow.
Hi Chandrasekhar,
I have some feedback on your design, and some questions below:
Kris
Hi Kris,
Thanks for the review.
6. This regulator is used to power up the peripherals used in the design and hence we considered 50% transient current (i.e 11A). Output capacitors are chosen according to calculations given in the datasheet and also values used in the reference EVM.
7. As of now loop compensation is only through pin-strapping for MSEL1 (I didn't get how to select the option for Loop-compensation through PMBUS).
Hi Chandrashekhar
There is PMBUS register to change the compensation as well. Please see details in the datasheet.
http://www.ti.com/lit/ds/symlink/tps546d24a.pdf#page=125
Gerold
