Other Parts Discussed in Thread: LM5170
After entering the appropriate data in the LM5170DESIGN-CALC spreadsheet found in snvc205, I have determined the Buck and Boost mode voltage loop compensation parameters as given in Section 11 and Section 12 of the spreadsheet respectively. This has allowed me to find the digital coefficients by using the Bilinear transformation which is required since we're using a microcontroller to perform the duties of the analog compensator.
(1) Is this the recommended/correct approach?
(2) The Buck and Boost mode voltage loop graphs shown in the LM5170DESIGN-CALC spreadsheet show the gain and phase margins. Can you share how this was determined as I'd like to understand the correlation between the information entered into the spreadsheet and the graphs. Where can I find the calculations which produces these graphs?
(3) The loads of our system will naturally vary. Would it be suggested to have coefficients at one particular condition or to have multiple coefficients for different conditions and select the most appropriate?
