My design uses a 2-cell NiMH battery pack and a 5V input source for the battery charger.
I have a couple of quesions:
- Which would be a better charging IC choice (BQ2000T or BQ2002T)?
- Which would be the best choice to isolate the resistor divider on the BAT pin from the battery pack when the 5V input source is removed:
- Move input isolation diode from between 5V input source and switching transistor to between the BAT pin's resistor divider and the BAT+ connection?
- Add N-channel FET in series with lower resistor in BAT pin's resistor with gate connected to 5V input source?
