Part Number: BQ25155
in the latest revision of our product, we accidentally left TS pin floating and the battery management started to behave strangely. When no battery is inserted and we plug in USB to power up the VIN, the MR pin quickly goes up and then falls to the low, which means that the device won't boot because it is in the reset state. However, when we plug in the battery and USB, everything works as expected. All power rails all good no matter if the battery is inserted or not.
The MR pin is weird only without the battery and we hadn't this trouble in the last revision where we had the TS pin grounded. I suppose that the TS pin needs to be grounded to be able to operate the BQ25155 without a battery. Could you please confirm this information?
Lukas
