Hi Team,
My customer is surveying isolated 10V output power module solution, the input voltage is 10V. Iout is 0.2A, is there any recommended solution?
Thanks a lot.
Vincent Chen
Hi Team,
Thanks a lot.
Vincent Chen
Hello Vincent,
There are some things to consider here:
1. If they need a simple ready to go module they can use UCC12050 and parallel 4 of the units together. The advantage of using this part is the integrated transformer reduces the total BoM and the whole solution will be very low profile. https://www.ti.com/tool/UCC12050EVM-022
2. Are they open in using a Flyback with a lower UVLO startup threshold similar to LM attached is the EVM board for their reference.https://www.ti.com/tool/LM5180EVM-DUAL
I hope this helps.
Sonal
