Please kindly help us to check the circuit, BQ25700A
Thank you so muchbattery and changer schematic.pdf
1. You are right. During OTG, the energy flows from the battery to the Vbus. Q1/2/3/4 will switch to regulate the OTG voltage, BATFET Q5 will be on.
2. When there is only a battery, the REGN will be ON if Low Power Mode Enable (EN_LWPWR)=0 , the REGN will be OFF if EN_LWPWR=1 .
