Hi expert,
How to set the maximum frequency when the burst mode disable?
Which limit is applied BMTH or BMTL?
I want to limit the maximum frequency to stop hard switching.
thanks
yuki
Hi expert,
thanks
yuki
Hi Yuki-san,
When BW is programmed to option 7, the BMTL thresholds become a minimum VTH-VTL switching threshold for VCR. Making the BMTL threshold to be larger, the maximum allowable switching frequency will become lower. Making the BMTL threshold to be smaller, the maximum allowable switching frequency will increase.
At light load, the VCR peak to peak will be dominated by the internal frequency compensation ramp. If you know the maximum switching frequency you need, you can estimate the needed BMTL threshold by calculating I=C*dV/dt where I is 2mA, C is the bottom VCR capacitor and dt is 1/2 the desired fsw period.
Ben Lough
