Part Number: BQ27421-G1
Other Parts Discussed in Thread: BQ24296
Hi Export,
Customer would use gauge BQ27421-G1 + charger BQ24296. Simple schematic block is like below. Would you please confirm the connection is correct if the pack would be removable? Can BIN pulldown resistor also connect to the T pin from the battery pack?
Second question is about the temperature measurement and learning. BQ27421-G1 don't need to do learning cycle to get golden image, but how frequently host need to write temperature value into the gauge for accurate RSOC update?
Allan
