Part Number: LP87524-Q1
Hi all,
Can you tell me the detailed PIN 1 ID detailed pad shape as below (red circle)? What is the length of the diagonal part of PIN 1 ID?
RYO
Hi all,
RYO
Are you working on layout for the part? There is detailed land pattern described in the datasheet you should follow. For the pin 1 the land pattern is the same as for other corner pins.
You can also download footprint/3D model in the product folder https://www.ti.com/product/LP87524J-Q1 under the Design&Development and CAD/CAE symbol.
Thanks.
Tomi Koskela
