Other Parts Discussed in Thread: TPS2663
Hi team,
My customer is considering using TPS2660 to limit inrush current. there have some questions:
1. DS says a minimum 0.1uF needs to be connected to IN pin. Is this input cap mandatory? Since it has some influence on surge current test, customer wants to confirm that whether can remove it.
2. Customer doesn't need OVP and UVP function, how to deal with OVP pin and UVLO pin? Can we leave these 2 pins floating?
3. The \SHDN pin has an internal pull-up resistor and Avdd supply. What are the value of this resistor and Avdd supply? since customer want's the device in shutdown mode during power-up and then enabled by MCU (MCU is supplied by another rail), an external pull-down resistor needs to be added in \SHDN pin.
thanks a lot.
Yang
