Hi Team,
The Internal FB resistor divider is implemented in TPS610994 (fixed output voltage versions). Would you please share how to measure the GM/PM for it?
Albert Lee.
Hi Team,
Albert Lee.
Hi Albert:
The internal loop compensation is same between fix and adjustable version. You could use TPS61099-EVM for bode plot test.
Hi Sir,
Could you kindly advise us what R1 and R2 values should be to simulate TPS610994 by TPS61099? We found TPS610994 has much lower leakage current than TPS61099(R1=825K, R2=390k)
That means TPS610994 should have higher embedded resistence inside.
Thanks.
Blake
Hi Blake:
Actually, the feedback resistance exact values do little influence to the loop. You could use Rbot=1 Meg ohm.
