Other Parts Discussed in Thread: BQ77905, BQ77915
I was going through the datasheet of over voltage protection IC bq2947 and there I found a PWPD pin at the bottom plane of the IC.
What's the use of this pin? Is this internally connected to VSS pin of the IC?
What if I left it floating as it is without connecting it to VSS pin? Does it impair any feature or safety of the IC?
In cases of series combination of cells greater than 4, say 13S/14S, in those cases is it necessary to connect PWPD pin with VSS for all the ICs used? If not done so, what will happen to circuit performance?
Please help me understand this. Thanks
