Hi Sir
May I know TI have buck boost switch converter with battery monitor ?
As I know TPS6274x series have this kind of solution
Ricoh solution RP605
Hi Sir
Hi Kaile:
Do you want to shutdown the system if battery voltage is low, or just monitor it?
If the former, TPS63805 has precise EN voltage. You can use that.
If the latter like RP605, is it enough with divided resistance?
Hi Kaile:
As long time no hear from you, I assume you have solved the issue. If not, just reply below. Thank you!
Hi Minqlu
Thanks for your reply
We need to monitor Vin battery voltage ,RP605 integrate voltage buffer and resistor divider could be easy to use for MCU
HI Kaile:
Sorry for delay reply. I'm out of office these days.
We don't have such voltage monitor function till now. May I know how important the buffer is for your system?
Hi Kaile:
