Hello team,
I want to increase the Rin(voltage monitor filter resistance) up to 10kohm even if response ability be sacrificed.
Is there any technical max limitation for this resistance?
Thank you.
Oliver Kim
Hello team,
Thank you.
Oliver Kim
Hi Oliver,
The data sheet does not provide a maximum recommended resistance. Do notice the specification for
IIN Input current at VCx pins
and consider this is an average current, check performance when using values significantly larger than those shown in the typical values.
