Part Number: TPS63900
Hi, can you provide the efficiency vs load current graph for TPS63900?
The load current range on x axis is from 1uA to 100mA.
Hello GOT,
You can find the efficiency graph on page 21 of the datasheet. The pre-production samples have a silicon issue and it will take some more weeks until we can deliver the requested data correctly, see the CAUTION box on page 4 of the datasheet:
CAUTION:
The pre-production samples with XPS63900DSKT orderable part number (top marking:
X639) have a silicon issue which causes leakage of around 300 μA in normal
operation. This leads to a reduced efficiency at light loads.
Hello GOT,
It took a while, but now you can find the efficiency for an output voltage of 3.3V from a load of 1uA in this file:
https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/196/D007_2D00_SLVSET3_2D00_01.emf
