BQ24075: BQ24075 not charging
Part Number: BQ24075
Dear community
I have designed a Li-Ion charger with the BQ24075 based on the schematic below.
Problem: When I connect a voltage at IN (5V, current limit >2A), the LED at the CHG pin is illuminated, but the battery is not charged (I measured the battery current)
Further information:
- Without anything applied at the IN pin, the battery voltage appears at the OUT pin, so this seems to work as expected
- I connected a 10k NTC at the TS pin
- The only difference I can see compared to the reference schematic is that EN2 and the charge LED are connected to IN instead of OUT. As those are digital terminals, I don't expect problems from this
Any idea what could be the problem?
Lukas
