Hi Team,
Would there be any EVMs available for BQ25505? I could not locate relevant info from ti.com site.
Please kindly let me know if there are any other boards also work for this part by re-soldering, it is acceptable.
Peiheng.
Hi Team,
Peiheng.
Hi Peiheng,
The BQ25570EVM uses the same PCB as the BQ25505EVM. After changing the IC, you will need to remove the VOUT components and add the external FETs for the MUX if used. BTW, the boost charger in the 570 and 505 are the same.
Jeff
