Hi team,
I have two questions about TPS92611-Q1. Schematic is showing as below.
1. We couldn't pass the below test when we setup in Vout. (Vout will damaged), could we add a ESD diode to pass the test?(if ESD could, could you help suggest the ESD spec) or any suggestion?
2. If we don't have LED in the output, could we use Electronic load to simulate the LED? How could we set the E-load mode and its setting?
Roy
