UCC256302: after the burst operation
Guru 11170 points
Part Number: UCC256302
Hello E2E,
In an individual, on the board using UCC256302, when the burst operation is exited, high side FET become to on at ISNS during fall down.
Please ket me know, is it normally? or malfunction?
e2e.ti.com/.../TI_5F00_Inquiry.xlsx
ACGUY
  • We have received your inquiry and are looking into it.
    I believe what your are observing is the converter detecting zero current switching when it comes out of burst mode. The controller will adjust the gate drive signals and frequency until the converter is not zero current switching on the primary.  I believe this is normal and should not cause any issues with the design.
    Please refer section 6.13.14 ZCS Region prevention and figure 29, 39, 40 and 42.  When ZCS switching is detected the SS voltage is pulled down through Rdischarge.  This resistor should have been labeled RSSdown and is roughly 447 ohms.
    If you relook at HO, LO, and Isns you will observe this is what is occurring.  If this is not causing an issue with output voltage ripple, I would not make any adjustments to the design.
    Please let me know that why did not happen that operation on other device? I want to know reason that what different each device operation.
    ACGUY
    The difference may be due to resistor and capacitor tolerances on the VCR, LLC and ISNS pins.
    Thank you for reply.
    I will suggest device swap between each boards to customer.
    BR,
    ACGUY
