Hello Team,
I have a question. Can TPS7B4250-Q1 use as usual LDO? It means ADJ/EN-pin is able to use as feebback-pin of usual LDO. (Of course, The external voltage divider is required.) I looked at the datasheet it seems reference voltage is required except input voltage. That's why I am asking. If TPS7B4250-Q1 is able to use as usual LDO, would you please tell how to set output voltage? (Vin=8V+/-10%, Vout=6V)
Fujiwara
