Hi TI E2E Team,
in the typical application of the LMG1020 you recomennds at leat 2hom resistor at each OUTH and OUTL to avoid voltage overstress.
But you let it open to use smaller resistance values when asked to contact you.
In the thread you answer that if oscillations and thermals are ok then you could using resistance smaller then 2ohm to achieve 400ps.
There are some test with resistance smaller then the recommended?
Best regards
Stefan Sattler
