Hi Experts,
Datasheet suggests that the pull-up resistor at PG pin should be 10-100kohm, can customer use 2.15kohm here? Because the PG pin is connected to the PORST pin of MCU, which has an internal 15kohm pull-down resistor. If customer use 10-100kohm pull-up resistor at PG pin, the voltage level at PORST would not be suitable. So they would like to use 2.15kohm for PG pull up, is there any risk? Thank you.
