Hi experts,
My customer set the watchdog timeout of TPS3851-Q1 as 200ms with below configuration(CWD pulled up to VDD through 10k pullup resistor). In theory, if there is no WDI signal, the WDO timeout should be 200ms, but customer found that the first timeout after watchdog enabled is a little longer than 200ms(around 250ms) as the waveform shows. Is it a normal phenomenon? I didn't find any description of this from the datasheet. Could you please help to explain it? Thank you.
