Hi
From the functional block diagram of the TPS61096A I can see there is a FET between VOUT and VOSNS. I am assuming this is used to disconnect the feedback network when the device is disabled to reduce leakage current? However, this is not clearly explained anywhere in the datasheet. Please can you advise the thresholds for turning this FET on and OFF - is it directly linked to the ENABLE function.
Secondly, if the level shifters are not required, should LV1, LV2, HVO1 and HVO2 be floating or GND?
Jim
