Other Parts Discussed in Thread: TPS61170
Hi team,
Do we have 12V Boost with bypass feature like TPS61099?
If we don't, could you recommend a suitable device for below application?
Vin: 12V
Vout: 12.13V @0.5A
Thank you!
Hi Miranda:
May I know the purpose for bypass feature? Is it OK for non-synchronous solution like TPS61170?
If customer need to regulate Vout well even Vin is close or higher than it, I'll recommend to have a look at TPS61378. (But it may a little oversize.)
Hi Miranda:
As long time no hear from you, I assume you have solved the issue. If not, just reply below. Thank you!
Hi Minqiu,
Customer used TPS61170 as you suggested, the circuit works well.
Thank you!
