If TPS3850-Q1 Voltage Supervisor trigger the RESET, will the WD timer reset at the same time? Thanks!
Hi Tom,
The watchdog timer's output, WDO, is separate from the monitor's output, RESET. That being said, while the device is in RESET, the pulse on WDI will be ignored as described in section 7.3.6.2 of the datasheet. This will cause WDO to continue its operation high.
Abhinav.
