Other Parts Discussed in Thread: TPS54202
Hello guys,
One of my customers is evaluating TPS54302 for their new products.
They have a question as the follow. Could you please give me your reply?
Q. They think that some currents flows from VOUT to VIN when VIN is powered off because VOUT is larger than VIN in the situation.
Is it necessary to add any bypass diode (fron VOUT to VIN) for avoiding reverse current flowing into TPS54302 when input voltage is powered down?
TPS54302 datasheet recommends to use 44uF~66uF as the output capacitor. But they are using about 100uF output capacitor due to some reasons.
So they think the reverse current will be larger than 44uF~66uF output capacitor case.
Is it necessary to add the bypass diode?
Your reply would be much appreciated.
Kazuya.
