Dear Specialists,
My customer has an inquiry about TPS23754 ON/OFF control method.
I would be grateful if you could advise.
We would like to turn ON/OFF the PoE power supply while connected to the PoE hub.
Generally, I think that POE turns off the power by pulling out the PSE side or LAN cable.
We are considering a method that can be turned on/off on the PD side with the LAN cable plugged in.
Looking at the datasheet, it seems that there is no simple EN pin.
Is there a terminal that can be controlled like the EN pin, or is it used to turn the IC ON/OFF?
I appreciate your great help in advance.
Shinichi
