Ulrich
So we had our 3rd proto built up & it showed exact startup SWS & HVG.
We pumped fist & proceeded with further circuitry put in action to go for the PWML...nothing special ..just solder the xmfr .
BUT did not happen. I see VSWS pin stuck at 2V ...no reason to push higher ..
WHY?
I suspect the exposed pad is cold soldered as it happened last week.
Is here a test we can do before biasing to test for exposed pad to PCB pad connection by application of some DC at a strategic node in the controller without any damage?
As it stands now, we have to undo all additions , reflow the pcb hoping to get good solder flow inside.
A test will be highly useful, if it existed.
robin
