Other Parts Discussed in Thread: LM7321, LM5176
I'd like to ask you some questions about two parallel configuration of LM5176-Q1, The related old thread and reviewed schematic are as follows.
Could you explain my customer's questions below in more detail?
1. CC_LIMIT is used only on master of LM5176-Q1 through guide of reviewed schematic. It says that "Use the CC_LIMIT to control the master, and The slave will follow by the sharing circuit". I want to know how to control the current sharing circuit by CC_LIMIT only of master.
2. When CC_LIMIT of master is off, output voltage is being moved between 0V and 3V in CCM. I want to know the reason why, and whether it is controlled by the current sharing circuit of LM7321.
