We're designing with the UCC2416 and seeing odd behavior with the gate drive signal.
Could you please let us know how we could troubleshoot / fix this? Thank you, Keith
Hi Mike,
We have a 2.2 Ohm resistor from the VG pin of the controller to the gate of the FET (Assuming you meant VG instead of VD). We also tried a range of resistances to see if that would solve the issue between 2.2 ohms and 50 ohms and saw no change.
Thoughts? Thank you, Keith
We found that adding a snubber across the MOSFET, as well as changing the MOSFET to a device with higher Rds_on fixed this issue.
Thank you for your help, Keith
