Mini ups for router
Other Parts Discussed in Thread: BQ25792
Hi TI team, Good Evening.
We are developing Mini Ups for wifi-routers to backup for 2hours and we are using Lithium ion battery's(2000mah) so kindly suggest a charging Ic and boost converter.
Rakesh Nampalli
  • Hi Rakesh,
    Good evening, for charging IC, would you please help me understand the below?
    1. What is the battery configuration in other words how many cells in series?
    2. What is the input voltage and the input source?
    3. What is the charging current you want to charge the battery at?
    Thank you.
  • Hi Upal Patel,
    battery configuration: 3.7v, 2000mah.
    maximum charging voltage: 3.7V
    cells: 4 cells are connected is series.
    input voltage: 12v Dc
    input source: 12v Adaptor
      To charge battery: 1Amp maximum we are using.
  • Hi Nampalli,
    Thanks for sharing this information. You may consider BQ25792 for the above requirements. BQ25792 is a buck-boost integrated charger IC.
    Regards.
