Hi folks,
I'm using the TPSM82810 and trying to configure WEBENCH for my design. According to the datasheet I see three options for setting the COMP_FSET resistor to set the compensation but no matter what I se the supply to in WEBENCH the RCF resistor value does not change.
I am using the supply for two rails:
3.3V to 1.8V @ 3.0 amps
3.3V to 0.9V @ 4.0 amps
Is the WEBENCH model incorrect? Should I leave the RCF resistor at 10K = 1.8MHz FSW per WEBENCH, or should these values be tweaked?
AH
