Other Parts Discussed in Thread: BQ24715, BQ24105
Hello
I downloaded the TEMPSENSE-SW File.
But , the downloaded file is BQ24715GUI.
Please Check the TEMPSENSE-SW File.
Best regards
Hello
Best regards
Hi Louis,
Thanks for bringing this to our attention. I will check on this and get back to you soon.
Angelo
Hi Angelo
How long do I have to wait?
Could you provide the TEMPSENSE-SW File?
Best regards
Hi Louis,
I have reported the incorrect Temp Sense link to the appropriate team within TI, but at the moment, I don't know an exact date for when the link will be fixed.
In the meantime, which charger IC are you using? If you have questions about the BQ24715, then I can support you here on this thread. If you need to calculate TS resistor divider values for some other charger, then please create a new E2E thread with the charger's part number in the thread title, and we will be able to provide further support there.
Thanks!
Angelo
Hi Angelo
When I inquire, I set the part number to TEMPSENSE-SW.
I need TEMPSENSE-SW for TS resistor setting of BQ24105.
Best regards.
Hi Louis,
Okay, thanks. If you haven't already, then please create a new E2E thread with the BQ24105 in the title so we can provide further support there. In the meantime, I will update you about the Temp Sense software once I receive more information about its availability. I apologize for the delay on this and will let you know as soon as I hear back about the Temp Sense software.
Angelo
Hi Louis,
The team has looked into this, but unfortunately, the Temp Sense software is no longer available. I apologize for the inconvenience.
Thanks for creating the BQ24105 E2E thread below. The formulas for calculating the RT1 and RT2 resistor divider values are given in Section 8.3.2 of the datasheet. If you need more support with this, please let us know in the BQ24105 E2E thread below, and we can help you calculate the correct values.
https://e2e.ti.com/support/power-management/f/196/t/952959
Thanks!
Angelo
