Other Parts Discussed in Thread: TPS92692, TPS92691
Hi All,
I have read that when PWM dimming is not required the : "When dimming is not required, connect the DIM/PWM pin to the VCC pin". Does it mean it will also disable analog dimming if I connected DIM/PWM pin to Vcc?
If I don't need to use PWM dimming do I still have to use the P-FET dimming connected to PDRV?
