Other Parts Discussed in Thread: LM25066, TPS24720
Hi Team,
Also, the customer are using “TPS259827O” which is a circuit breaker type.
Please help to check if they can use Rilim to GND (0ohm) get about 20A circuit break point (This meet spec also 20A is close to our test result of now).
If this is workable, please kindly share what is min of ICB.
Also, it seems that the RILIM minimum value of TPS259827O is not limited by the DS recommend Operating Conditions
Can the customer use RILIM as 64.9 ohm in their design? Thank you.
Mike
