TPS26630-33EVM: TPS26630-33EVM Latch-off does not work for undervoltage lockout
Part Number: TPS26630-33EVM
Other Parts Discussed in Thread: LM5069
I did some tests on TPS26630-33EVM board. I'm using DC load and battery. EVM is not latching-off like overcurrent fault while undervoltage stage. When I disconnect the load, voltage getting higher. If EVM is going to overcurrent fault, I need the use the button for reset. I want to use the same feature for undervoltage fault.
Thanks.
